 TabberJohn
                    Member Posts: 588
TabberJohn
                    Member Posts: 588
            First clue is the latch bolt does not strike the catch plate on the beveled lip of the bolt.
You have to slightly depress the plunger in order to push the door closed.
However, no matter how hard you push on the door it never latches.
I plan to file down the aluminum catch plate about 1/8" so it will strike the bevel and there will be less travel to engage the plate.
Before I do that I'm wondering if anyone else has run into this issue.
If your access door closes fine, how does the your catch plate height compare to mine?
Thanks.
I learned that the hard way, but here's a tip to anyone who needs to work in that area. Tape a sheet of plastic or stuff something across the opening BEFORE you stick a tool in there or unscrew any part from the water pump.
