I have a 2016 Tab Outback Max S. I live in Montana and want to use the trailer during our extended winter. That means I will be using the Alde after the trailer has been winterized.  I've already emptied water using the Alde release valve, the freshwater tank drain valve, and both the gray and black water gate valves. I plan to use the antifreeze method of winterizing and do not want the hot water heater to be heating antifreeze all winter. I'm assuming that I should make sure that the hot water drain valve has been opened to allow water stored in the water water unit to drain, then close the Alde bypass valve and the hot water valve before pumping antifreeze into the rest of the system. Last year, the dealer winterized the trailer. When I was using the furnace, antifreeze was leaking out of the faucet. When I opened the cold water faucet, boiling hot antifreeze blew out. I do not want to have that happen again. But I do not want to damage any of the plumbing in the trailer over Montana's long winter. What procedure should I follow? (I do have a compressor, but have not used it before--willing to try if that would be more likely to be successful).
                1 ·
You can run the Alde furnace without water in the hot water tank.
2014 T@B CS Maxx
Martha Lake, WA
