If you winterize by using an air compressor to blow all of the water out of your lines, why would you have to add RV antifreeze to fill all the tubing?Shouldn't it be enough to do one or the other, but not necessary to do both?
(I know that you do need to put some RV antifreeze in the drains for the shower, sink, toilet, and the gray water and black water tanks.)
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx
2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V8
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
What is the reason to drain and blow out the antifreeze at the end?
