So, this brake controller...
gophergrad
Member Posts: 115
Picked up the T@b today, and got a brake controller. I don't necessarily see a way to turn it off..... And the instructions don't mention it. Should it be left on, or turned off when not in use?
The box says it's a PrimusIQ.
thanks!
thanks!
2017 CS-S Max (Silver & Yellow), TV 2019 Ram 1500
Camping under the Big Sky
Mine's always on when the vehicle is running.
Thanks, PXL.
Camping under the Big Sky -
Most brake controllers are always on. Also most are adjustable. If yours is, while sitting still hold the break pedal down and turn the adjustment until the indicator light goes from green to red. That should be about the right amount of braking.
I have mine wired to the ignition side so it turns off when I remove the key.
The manual recommends to wire directly to the battery but many reviews went negative due to drained batteries. Go figure, whatever. It works well regardless. I have the prodigy p3.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
