We are putting our new (to us) 2007 T@B away for the winter and we have a winterization question.  The T@B is very simple. There is a 5 gal fresh water tank with water pump but no grey water tank.  Waste water just drains out the bottom of the T@B.
We drained the fresh water and pumped the sink faucet till it did not run any more.  Do we need to put in some antifreeze?  Our friends with the barn thought we should but it all looks so simple I cannot see where we might have a problem unless it is in the pump.
Any advice would be a big help.  Thank you.
                0 ·
You didn't mention a water heater. If you have one, make sure to drain it but do not pump antifreeze into it, instead use the bypass, which should be next to the water heater under the sink.
Sterling, VA
