Grr....searching for cushion (bed) dimensions...
LauraRey
Member Posts: 338
I know that I've seen it in the forum. However, my search-foo seems to not be working. I'm looking to see the dimensions of the bed area in the Max-S. I know the official brochure says 70 x 73, but I was going to confirm that before I bought the mattress topper.
We should have a new category..."Searched, but can't find".
Red and White, 2017 Max S being towed by a 2014 Honda Ridgeline. Hello Mountains!
70x73 is correct. But... before you do that, do you have the T@B handy so you can measure? We ordered 70"x73", 2" memory foam mattress that came with a cover and straps for rolling it up,and we use a queen sheet set, and it works out well.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf -
No, it won't be in my driveway until Wednesday.
So, no, I can't go measure and I'm kicking myself because I meant to do it today at the dealership and totally spaced it. I was planning to order the same thing. What length elastics did you get on the corners? (If any)Red and White, 2017 Max S being towed by a 2014 Honda Ridgeline. Hello Mountains! -
That is correct. I bought a King size 2" gell memory foam mattress topper and cut it to fit and then cut down the middle lengthwise. I then got two sleeping bag liners and stuffed the foam inside. I then got four quick release sleeping bag straps to roll the two toppers up and store behind the rear bench...Kennesaw, Georgia
2016 Silver/Black T@B M@x S with Scuba Black interior. 2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller. -
LauraRey, No elastics, just a fitted bottom sheet.2016 T@B MAX S-aka: WolfT@B
- 916 Introductions
- 72 Teardrop Groups & Links
