Towing angle
I tow the T@Bpole as close to a 0° angle as I can. I also have had issues with the spare tire placement, which is why mine now travels on the roof of my tow vehicle. I have never heard of a problem with the gray water outlet, which is tucked pretty tight up under the frame, and fairly far back on the tongue. Is yours maybe lower then it should be for some reason?
Sterling, VA0 -
I swapped the stock wheel with one that swings up out of the way. The wheel tucks right in front of the grey water outlet when it swings up. Have attached a picture of the result. That should give me a bit more clearance for towing angle when going over bumps.0
Can you please advise where you purchased the swing up Dolly Wheel?andyhe said:I swapped the stock wheel with one that swings up out of the way. The wheel tucks right in front of the grey water outlet when it swings up. Have attached a picture of the result. That should give me a bit more clearance for towing angle when going over bumps.Ray and Vida Barrick
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada0 -
ETrailer.com has a good selection of trailer jacks and a nearby RV store or possibly a nearby auto parts store might have what you are looking for.
Tongue Jacks
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Hmmm.Anyone know how to delete a Comment you didn't intend, on this forum? 8-/
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Ask, and it disappears!!!! I'm not sure if you can delete it. Click at the upper right of your message. If a gear appears, click on it and select "delete", then look for the confirmation box, and click on "okay". If you don't get the gear, then I guess we Admins have to delete for you, which is no problem.Verna, Columbus, IN
Thanks Verna.
The gear appears, but only "Edit" shows when I mouseover the gear, no "Delete".
I've read that VanillaForums makes it optional for the sysops to allow us common users to delete posts. B-)
(I appreciate your efforts!)
Chan
A_Little_T@b'll_Do_Ya1 -
Chan-choose "edit", then select by highlighting, and then delete the text. Would that work?Cheryl, 2014 Jeep Grand Cherokee Diesel, 2015 T@b S Maxx (T@bitha)0
Well, that leaves an "empty" post....Kind of boring, like an empty wine glass.
The admin and moderators can delete a post, so send me a message, tell me which post you'd like deleted and we can make it happen.
It's true that Vanilla does have an option for members to delete posts, but the issue there is that if this functionality is activated it allows a user to delete others posts as well.
Thanks Mike, Verna took care of it.
Regarding the trailer wheel. Check out Jack-e-up. Google it. I installed this on my trailer and it is great. It allows the removal of the entire pole,turning handle, and wheel assembly once T@B is secured to Tow Veh. Great for access to rear of TV with no obstructions while opening swing door of SUV. Cost $60.00 Amazon.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
Will this work on tongue with surge brakes?deputydog said:Regarding the trailer wheel. Check out Jack-e-up. Google it. I installed this on my trailer and it is great. It allows the removal of the entire pole,turning handle, and wheel assembly once T@B is secured to Tow Veh. Great for access to rear of TV with no obstructions while opening swing door of SUV. Cost $60.00 Amazon.
No, the Jack-E-Up won't work with surge brakes (Little Guy's surge brakes - don't know about earlier Tabs)The surge brake cylinder and hose get in the way....
The Jack E up is at camping world now and in the store was only 40 bucks.The Mouse house and me0
That's where I got my Jack E Up (Camping World) - Works like a champ.0
Looks like a pretty slick set-up and eliminates all the grating issues or bent jacks!
https://www.youtube.com/watch?v=dD1M-t2eqxM&feature=player_detailpage#t=75
