12v outlets?
Sorry I know this is a silly question, but I just came back from viewing a 2017 T@B last week and as I was putting my notes and thoughts together I realised - I think I only saw 120v outlets and a few USB ports.
Did they do away with the 12v outlets on the new T@Bs?  If they were still there, where were they?
Sorry - major blonde moment!
2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
  • Tabaz
    Tabaz Posts: 2,420
    The only 12V outlet on my TAB is located on the underside of the cabinets above the sink.  It has a small black snap off cover.  Round "cigarette" style opening.
  • Nomad
    Nomad Posts: 7,209
    None down by the AC outlet on the drivers side bench Frank?
    That'd be weird, it's the one I use all the time.
  • ericnliz
    ericnliz Posts: 4,437
    OutbackAZ, Are you sure those aren't USB charging ports side by side? Mine is. My T@B is a 2016 Max S, what model is yours?
  • Nomad
    Nomad Posts: 7,209
    My over counter outlet is like OutbackAZs - 2 USB and one cigarette style with a cap.
  • ericnliz
    Pxl, Thanks, that's what I thought. My 12v outlet is like yours, down on the driver's side bench.
  • Tabaz
    Tabaz Posts: 2,420
    There is a USB charging port next to the 12V in the same outlet cover.
  • ericnliz
    OutbackAZ, Thanks for the clarification!
  • HR_Taly
    HR_Taly Posts: 119
    Wow, you guys are great!  Because it was capped with a black cap next to the USB ports (like in OutbackAZ's picture) I must have totally blanked on it.  I couldn't imagine a caravan without at least one 12v outlet, but worked myself up that with all the USB ports that they somehow might have eliminated them! Thank you all so much!!
  • Tabaz
    Tabaz Posts: 2,420
    "Caravan?"  Did you call it a "caravan?"  You must not be from around these parts!  =)
  • ericnliz
    HR_Taly, Ask and ye shall receive! =)
    Ditto here. Dual USB and one round 12v connector on outlet above the sink. Drivers side outlet is AC only.
    Anyone know what the amps are on the USB ports?
  • Photomom
    Photomom Posts: 2,217
    Don't know the number, but the USB outlets will charge my iPad and iPhone 6.
  • Cyclonic
    Cyclonic Posts: 1,232
    Hehehe, I thought the same thing.  Do Canadians use the term caravan for them?
    Sterling, VA
  • Verna
    Verna Posts: 6,876
    Don't know about the Canadians,  but those in Ireland do.
  • or England...
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
  • ericnliz
    Isn't it a caravan if there are more than one? ;)
  • HR_Taly
    HR_Taly Posts: 119
    Verna takes the prize!  And nope, caravan would be singular here... unless you mean convoy?  (and yes, I know I'm referring to US T@bs, I'm moving to the US for at least one year in April. The 320s and 400s are available here... well, I say "here" that mostly means in the UK as caravanning would definitely not be a thing people do in Ireland for obvious reasons!).
  • ericnliz
    HR_Taly, Verna has a magic wand, so that was kind of a given! I was just kidding about the caravan comment, but convoy was a good come back!
  • Verna
    Verna Posts: 6,876
    Yes, I used my "special wand", @HR_Taly. I needed to make sure the questions you were asking in the last week pertained to the US version and that you were getting and giving the correct information. I always try to make sure correct info is given to everyone, at least on the subjects I'm familiar with. When you start talking about yucky greasing of the bearings, I tend to zone that subject out ;).  (Your first hint was the fact you would be moving here for work.)
