While following a different thread. They were discussing the idea of needing a brake. To help stop your trailer while manually moving it around on a slope surface. Got me to thinking. I think early T@Bs have a hand brake. The newer ones with electric brakes have an emergency breakaway switch. By simply installing a momentary switch to the electric breakaway circuit. You would effectively have a controllable hand brake. Your thoughts.
                0 ·
Brings up a couple of questions though:
#1 Where would you install the switch where it would be handy to get to, especially if you were moving the trailer by yourself?
#2 How would you be able to access the switch to the brake-away circuit, and would it be in effect like an interrupter switch? Thanks
