T@b Outdoor light
While camping this summer we left our night light on so we could find out way back a friend's campsite after a night of playing cards.  The next day I noticed that the housing had discolored (looks like from the bulb being to hot).   Has anyone else experienced having the housing of their outdoor light discolor after use
States Visited Map
  • JandJ92010
    JandJ92010 Member Posts: 304
    Not yet, but we don't use it much. Even after tinting it yellow, it still attracts too many bugs, so we use lights on the canopy.
  • j_ntabowners
    j_ntabowners Member Posts: 131
    I hear you..  We usually only use it for a land mark in an RV park when making quick trips to the shower house and back in the dark. I have a set of lights we use with our t@b side tent, but on this particular trip we didn't set the tent up
    States Visited Map
  • Nomad
    Nomad Member Posts: 7,209
    Saw a new Outback today and it had a very slim led outside light fixture. I rarely use mine as it is a power hog.
  • Ratkity
    Ratkity Member Posts: 3,770
    I consider that light brighter than most functioning lighthouse lights. I don't use it. That discoloration *does* look like it got too hot, which is odd since most LEDs don't put out as much heat as incandescents.
  • wizard1880
    wizard1880 Member Posts: 442
    Mine looks like that.  But from the sun shining on it.
    I found the original bulb took over 2A of power (that's almost more than the Alde!) so I replaced it with an LED bulb when it burned out (just from leaving it on overnight once!)
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • Nomad
    Mine is quite that barren but over half the silver is now weathered off - same with the T@B logo.
  • j_ntabowners
    Thank you for satisfying my curiosity.  Wizard, you are probably right about it possibly being tied to a product of too much Sun, I just may not have noticed prior to leaving the light on for an extended period of time.
    States Visited Map
  • larrygon
    larrygon Member Posts: 255
    Unfortunately this is a issue with these fixtures. It is caused by the plastic not being UV resistant not heat. If you search the site, there is a good tutorial on removing the fixture and replacing/painting it.
    "Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
    2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
  • LauraRey
    LauraRey Member Posts: 338
    I was amused how bright it was.  I doubt I'll be leaving mine on much at a campground.  It is indeed on par with functioning lighthouse lights.
  • TabberJohn
    TabberJohn Member Posts: 588
    edited December 2016
    Has anyone tried to add a dimmer switch? Do they make them for 12v switches?
    Or a 3 position rocker switch (off, low, high).
  • Verna
    Verna Member Posts: 6,876
    I found a double dimmer switch on EBay, but I haven't installed it yet. I need to fire up the Alde so I can work in the T@B.
  • TabberJohn
    Double would be great so you can also adjust the overhead light.
  • Verna
    That's why I ordered it, @TabberJohn. It overhead light is rather bright for morning eyes ;)
  • JandJ92010
    I'm not sure that 12 volt LED lights are dimmable, unless they are made to be.
  • Verna
    @JandJ92010, then EBay is making a killing with all of the dimmable 12V LED switches they have ;)
  • trainwrecked
    trainwrecked Member Posts: 31
    I installed this dimmer on the outside light (I have the slimmer version of the light which is reported to be dimmable).  Light was way to bright for my taste most of the time, but I can crank it up when I need it.  Works great, just don't hook it up wrong the first time - bricks the switch, found out the hard way...
    2016 T@b M@x S Sofitel >- 2017 Subaru Outback 3.6
  • wizard1880
    The LED bulb I replaced it with is only 70% as bright as original.  No dimmer needed. :)
    https://www.amazon.com/dp/B01DSIZAKK/ref=cm_sw_r_cp_apa_YHYuyb92SDCH2
    Seems it's only sold in a 6 pack now...
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • SweetlyHome
    SweetlyHome Member Posts: 336
    I've read several threads on replacing this bulb.  Getting that cover off makes me real nervous.  Any hints?  Which side do you start on?
  • wizard1880
    Use a tiny flathead screwdriver, and work your way around the top trim piece.  Before you know it, it will pop right off.  Then, use Philips head to remove the 4 screws holding on the lens piece.  That's about it.  Install is reverse of removal.
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • Estancio
    Estancio Member Posts: 243
    I just replaced the entire unit with an LED version of the same fixture. Works great. From E-Trailer.
    Stancil Campbell
    2011 T@B
    Rockingham, NC
  • wizard1880
    Sweet, that works too!
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • larrygon
    Here is a link with instructions
    http://tab-rv.vanillaforums.com/discussion/838/install-amber-led-sidelight-on-trailer/p1
  • SweetlyHome
    Thanks, starting at the top seems to be the key.
  • TabberJohn
    edited May 2017
    Did this turn out to be a bust because the stock bulbs for the inside/outside lights aren't dimmable?
  • Verna
    @TabberJohn, I just didn't get "round tuit"!  I found it again Sunday as I was packing to come back home. I'm still going to try it, but I intend to leave slack in the wiring, just in case it doesn't work.
  • RollingBnB
    RollingBnB Member Posts: 322
    I put two layers of taillight repair tape over the LED light, changed it to amber and toned it down quite a bit.
    2020 Tiffin Open Road
    2020 Nissan Versa Toad
    Alan & Patty
    Southern Az
