Removing Aerator
System
Administrator Posts: 188
This discussion was created from comments split from: Kitchen Sink Faucet.
Help I have a 2017 Tab S and I can't unscrew the existing aerator. Does it screw in? It is rounded so it's hard to get a grip on it.2017 Tab Max S (Silver/Black) 2013 Ford Edge
Attach a photo (no wider than 800 pixels
) so we know what it looks like.2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow) -
Hi, vegascacher, I have a 2017 tab CS-S also have that faucet.. they don't unscrew there is a little slot at the top ..pry open and pop out its a tight fit... I had to clean mine out... no way to put a standerd aerator on ..no threads inside..good luck... 2017 T@B CS-S tv 2016 Honda pliot2017 T@B CS-S Max ... 2020 Honda Ridgeline RTL-E
Thanks for the info. I guess ill have to change the faucet when I get time. I was looking for a quick fix.2017 Tab Max S (Silver/Black) 2013 Ford Edge
I have that faucet. It's articulated and I haven't found a reason to either attach an aerator or replace it.John and Henrietta, Late 2016 T@B S Max in Western New York
If it helps, the faucet is normally used in the marine industry and works very well on boats.Verna, Columbus, IN
- 919 Introductions
- 74 Teardrop Groups & Links
