How does the Ridgeline tow?
System
Administrator Posts: 192
This discussion was created from comments split from: What battery should I upgrade to?.
How does the Ridgeline tow?0
We have a 2009 Pilot and if you are talking about the old Ridgeline , it has the same drivetrain as ours . The problem with these vehicles is a lack of torque in the low RPM range .Even towing a lightweight trailer like a T@B , going up any hill causes multiple downshifts and high revs and bad mileage .No hills no problem .The newer models should be better , direct injection drops the peak torque down 1000 rpm's .2014 T@B M@XS; 2017 Ford Transit Low Roof, Reg. Wheel Base2
