Alde System won't run
tabluosity
tabluosity Member Posts: 4
Hey there,
We went to start our Alde system tonight and it  will run.  Plugged into shore power and propane is on.  Power and fuses all ok.....any ideas?
We've tried to open breakaway's new manual, but don't see a way to actually open or download it.  Help?  We are cold!
Thanks so much,
Marnee
  • tabluosity
    Sorry, I meant to say that it will NOT run.
  • judymac
    judymac Member Posts: 403
    Have never started ours, but do you have gas on as well? In order to open manual, I have to be logged in. I am sure someone will chime in soon! Good luck.
  • judymac
    Sorry, just saw you do have propane on. Have you used it before?
  • judymac
    I am unable to copy/paste. It states gas setting is automatic. If gas AND electric are used together, the default is electric. Do you hear any clicking? Is your vehicle level?
  • tabluosity
    Hi,
    We are pretty level in the driveway, propane is on.  We turned lightning bolts to 3, gas on and thermostat to 5 and nothing happening
    Thanks for any help...
    Marnee
  • Nomad
    Nomad Member Posts: 7,209
    What do you have the third slider set on? Should be heat/water (center choice).
    When it starts you'll first hear a slight whir as the circulating pump starts up and then the boiler kicking in. If you can't hear it from within the T@B, try listening at the vent next to the electrical hookup.
  • DurangoTaB
    DurangoTaB Member Posts: 754
    Have you checked to be sure the propane is working...e.g. by lighting the stove? I know that helps fill tthe line for the fridge to run on gas. Also, it sure sounds like a fuse problem...have you checked both tthose weird little fuses on the top of the Alde?
    J.D. & Sue
  • tabluosity
    Hi,
    I thought I had read in the manual not to turn on the hot water when tank is empty - but I think that is incorrect.  I turned on that third slider to middle position per PXlated and we are gurgling away....
    Thanks for all the help!
  • judymac
    Awesome! These forum folks have been so helpful and we haven't moved ours since purchase.
  • deputydog
    deputydog Member Posts: 103
    Glad you got heat tabulosity.  That IS the correct position PXlated told you. Its not a fluke. :):):).
    TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
  • Nomad
    Don't feel bad - That position had me stumped at first as I didn't want hot water and the two top positions both show water. The bottom position evidently keeps the circulation pump off and the Alde won't start up unless it's on.
  • Sgtjohn
    Sgtjohn Member Posts: 238
    edited November 2014
    We got ours running and took a photo of the controls with a cell phone and stuck it in with the trailer manual-just in case we get confused again.
  • Rebar
    Rebar Member Posts: 29
    We are having the same problem EXCEPT that the controls are set appropriately and still, nothing.  No whir, no gurgling.  Nada. So, DurangoTab, tell me more about those "weird little fuses" on top of the Alde unit.  :-)  It is behaving as if it is not receiving power.  No clicks, etc. when thermostat/controls are adjusted.  Another bit of info....we have had the tab on shore power in the driveway this winter, and around november, it stopped heating.  If it is fuses, is it okay to just start yanking them out and checking them?  Do I need to unplug from power/disconnect the battery?
    2014 T@B Model Q - Silver/Black Towed with 2014 Toyota FJ Cruiser (Orange) Live in Denver, Colorado "Bad decisions usually make for really good stories!"
  • Larry
    Larry Member Posts: 25
    Look for my post from Whistler BC! Our went out as well. Turned out that the control board on the heater itself went bad. Just had it replaced under warranty. No settings would get it to work including the "emergency start" procedure.
  • ChanW
    ChanW Member Posts: 3,171
    edited April 2015
    Rebar,
    That's behaving like the fuse problem. It happened on shore power with mine.
    There are two fuses, the old glass-tube type, on the Alde itself.
    Look in the Yahoo Group / Files, "ALDE HIDDEN FUSES.pdf". Link is here, for the info:
    https://groups.yahoo.com/neo/groups/tabtrailers/files/ALDE HEAT, HOT WATER UNIT/
    Be sure all power is disconnected before working on it.
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
