Winterizing
captainwings
Member Posts: 30
Aloha All, Second time winterizing this winter. First time I used RV anti freeze. Second time I drained and blew out the water lines. I used a cheapo 12 volt tire inflator, the kind you plug into cigarette lighter and 50 feet of garden hose. Attached garden hose to city water fitting on side of T@b and attached other end to air pump using a RV blowout plug. With all trailer faucets CLOSED I turned on the airpump and pressurized hose to 45-50psi . Opened faucets one at a time, pressurizing hose between opening of faucets, and blew water from all lines. Garden hose acted as a pressure accumulator and supplied ample air to blow out the lines. A lot less work and no issue flushing out anti freeze.
Cool - The antifreeze is a pain - Blowing is much easier.
Nice trick!captainwings said:Garden hose acted as a pressure accumulator and supplied ample air to blow out the lines. A lot less work
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)
- 919 Introductions
- 74 Teardrop Groups & Links
