Wheel Bearing Size or Parts Number
Jltab
Jltab Member Posts: 89
Hi everyone,
I have 2016 T@S S Max for a year now, I would like to inspect and lubricate the bearing. just in case I have to replace, any body know what size of bearing do I need? and what type of grease I need.
Thanks a lot!
2016 T@B Maxx S, Nissan Pathfinder
  • Nomad
    Nomad Member Posts: 7,209
    Have you search for "bearings" - been several threads. Believe I've seen those answered somewhere.
  • Cyclonic
    Cyclonic Member Posts: 1,232
    I can't help you with size or part numbers, but a call to the factory should answer that question.
    Unless the axle has really been driven hard or submerged, after just a year the bearings should be in good shape.  I have torn mine down three times now to clean and inspect and never found an issue.
    Sterling, VA
