J.D. & Sue
I lost the metal tag from my safety chain and was wondering if it was required in case highway patrol had some reason to inspect the trailer. I know many states require that all components of the towing assembly be labeled. I didn't find a definite answer to that question, but I DID find something else I should pass on.
I found regulations in three states (at which point I quit looking) that require that towing safety chains be crossed when towing. Those states were Maryland, North Dakota and Oregon. I'm assuming that other states have similar regulations.
So, guess I need to find a way to change the single attachment point on the chains on my T@B so they can be crossed. I don't know if folks at the factory are still installing single attachment points, but they may need to made aware of these regulations.
geromo said:my chains also are hooked to a single point. I bought a "snap link" rated at 5000lbs and attached it to both chains about 4-5 inches from the ball. If the hitch comes loose it "should" be caught by the link.
The best laid plans....sometimes turn out even better. After much effort, I was able to drill my first hole in the metal plate so that I could attach two separate chains. Then it dawned on me that I could use the bolts that attaches the plate to the tongue. (This is the plate on which the tongue jack is mounted.) I would, however, need longer bolts since the original ones would not allow the addition of the chains. I removed one and went to the local hardware store and purchased a couple that are one inch longer. I then replaced the bolts and attached the chain to the bottom. I bought two stop/lock nuts to attach the chains, then also put the original nut on top of that since I had the extra length in the bolts. I also bought extra washers so that I could have one on each side of the attached chain link. I then had to hitch the tow vehicle to the trailer so that I could get an accurate length and cut the chains with bolt cutters. Last step was to attach the hooks to the chain that I removed from the old one. Mission accomplished.
Note: During a break (I like to take breaks when I work), I was reading the labels on the trailer tongue. One of the items on the list of Warnings was to check that..."tow chains are crossed and attached to the tow vehicle." Hmmmm...reason I was doing the work because the original single-point attachment did not allow the chains to be crossed.
If you are getting a new T@B everything you need from the trailer side will be provided. You will just need a hitch and 2" ball. Have them show you how they attach a trailer, including chains and brake cable. After that read the report listed and make your own decision on how long you want the chains.DABWCA said:Silly question perhaps, but I'm picking up my T@B on Wednesday and wondering whether or not safety chains are typically provided. If not, what do you use -- how long? Reese, Tow Ready, etc.?
Lisa and Tim
Cottonwood, Arizona
2015 Max S Sofitel--"The Hatbox" TV: 2013 Subaru Outback and 1994 Toyota Land Cruiser aka "the Betty"
J.D. & Sue
Lisa and Tim
Cottonwood, Arizona
