Lug wrench
mandt
Member Posts: 158
my car lug wrench is the correct size for the wheels on my 2016 max s, but the problem is that I can't fit the lug wrench onto the nut because it is a tight fit between the nut and the wheel. Ideas?
mickey
mickey
Mickey & Terri
2016 Max S
Kalamazoo Michigan
2016 Max S
Kalamazoo Michigan
@mandt, Go to Amazon, look under folding lug wrench. Several to choose from, and nice & compact as well. Checked the one I have yesterday, fits, and works!2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf -
If you are saying what I think you are saying, you can't fit the socket on the lug because the space between the lugnut and the wheel is too narrow to fit the socket on the lug? If that's the situation, you need to get a thin-walled socket. I had this problem with my fifth wheel. Because I'm using the same socket for both my fifth wheel and T@B, I hadn't given it much thought that the T@B may also have a narrow space. I got my socket on Amazon.2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed -
They have a million of them hard to know,which one is thin walled. Might try a local auto parts store.Mickey & Terri
2016 Max S
Kalamazoo Michigan -
We had the same issue, bought one at the auto parts store.John and Henrietta, Late 2016 T@B S Max in Western New York
Sorry to be a bother, but can anyone tell me what size it is?Mickey & Terri
2016 Max S
http://tab-rv.vanillaforums.com/discussion/comment/22090#Comment_22090
11/16" socket for spare tire bolts for the bracket under the rear of the T@B and 3/4" deep well socket for the lug nuts on the tire. I use this lug wrench (under $15 at Walmart) but I did buy a deep well 3/4" socket that fit well on the tire lug nut.
Thanks for the help! Got everything working. Bought a 24 inch pipe to give me enough leverage to turn the lug nut.Mickey & Terri
2016 Max S
Kalamazoo Michigan
- 916 Introductions
- 72 Teardrop Groups & Links
