Just went out to the t@b to put some things away and plug her in for a charge and the access door above the toilet is hanging open. I have no idea how it opened or when. I just can't close it. I was considering loosening the screws that hold the hinge, buy decided to ask.
Thank you,
Denise
Denise, Rea and Ruby
2016 CS S, 2008 Toyota Tacoma
Somerset, VA
0 ·
Somerset, VA
I admit to having to leave it open a couple of times in frustration, only to come back 15 minutes later with a cooler head and was finally able to close it before he took two seconds to fix it for me.
You may have same issue as shown here: http://tab-rv.vanillaforums.com/discussion/3807/max-s-water-pump-access-door-in-shower-latch-wont-grab
No amount of pressure would work because the plunger wasn't clearing the top of catch plate.
Filing down did the trick for me. If you decide to do that, stuff something back there first to catch the filings unless you don't care what ends up in the "abyss".
If catch plate height is not the issue, then bending it towards you should help.
Denise
Somerset, VA
