Finally made it out of the driveway!
2Cougs
2Cougs Member Posts: 933
After having bought our T@B just in time to spend the night in the driveway, winterize it and put it in the garage, we finally had our maiden voyage!  Took off spur of the moment for Riley Creek, an Army Corp of Engineers campground just east of Priest River, Idaho.  Driveway to this pic was about 90 minutes.  Hardest part was the difficult hitch... definitely needs breaking in.
Cheers to all of you who have shared your knowledge, and to many more wonderful T@bventures! :)
  • Homebodyatheart
    A can of silicone spray is your new best friend! I use it liberally on my hitch and ball and after two trips it is getting much better! Works in the keder rail, and other spots, too! Congratulations on your successful maiden voyage!
  • ClaudeA
    ClaudeA Member Posts: 54
    We just bought a 2016 cs-s with red trim and same difficulty with the hitch.  Doesn't matter, still love the trailer anyway.  Enjoy.
    2016 CS-S silver and red, 2022 Toyota Sienna Hybrid
    Ottawa, Ontario
  • Newfisher
    Newfisher Member Posts: 105
    I had difficulty with my hitch as well. I now block the front of the drivers side wheel and then jump in the rig and tug on the trailer with the tow rig as the trailer is blocked. This helps alot! It seems to put just enough clearance in the tongue mechanism to release it.
  • Newfisher
    Great pic!
  • Tabaz
    Tabaz Member Posts: 2,420
    The ball cover on the hitch tilts up, then slides back. Takes a little getting used to. I sometimes need to wedge a claw hammer between the lower edge of that cover and the lip of the tongue to get it up and back. When the cover doesn't want to go down over the ball, simply get in your TV and very slowly start to drive away. Within a second or two, you'll feel the tongue seat on the ball. Get out and slide the cover over the ball. Silicone spray is also a big help.
  • ericnliz
    ericnliz Member Posts: 4,437
    @2Cougs, Nice & glad you two got a well deserved break! Next adventure??? Soon I hope! :)
  • JandJ92010
    JandJ92010 Member Posts: 304
    There is also an adjusting nut on the bottom side of the hitch socket to loosen the tension up a little. Had to loosen one up on one of my utility trailers.
  • 2Cougs
    Thanks everyone for the help... One of the things I love about this forum.... A hundred heads are better than one!
  • Tabaz
    J and j - was not aware of the adjusting nut.  Will try to find it.
  • TerryV6
    TerryV6 Member Posts: 1,101
    After a year of use, our hitch has gotten friendlier as it has probably been broken in somewhat.  The first time was nasty and some Vaseline  helped us...
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
  • creamsicle
    creamsicle Member Posts: 18
    Love the lights around the kitchen. I'm having the same problem with the hitch, will try grease and moving forward and back with my rig.
  • Homebodyatheart
    Creamsicle, I swear by silicone spray! I brought a can to our walk through and the tech sprayed the hitch handle, underneath, and ball liberally with it. I've sprayed it the first few times I've hitched up and now it is better, including spraying the trailer dolly. I also use it on our garage door runners, and a friends bike at the last T@B gathering. I love this stuff!
  • 2Cougs
    @creamsicle and @Homebodyatheart - ok... We have more experience and more knowledge now.  Silicone spray helps, but even more so we found a "secret button"!  Under the tongue there is a small U shaped bracket.  If you pull it down before you lower the coupler, you can get the U shaped bracket low enough so when you let go of it that "sticking" where the coupler won't seat on the ball no longer happens, and the bracket can now grab the bottom of the ball.  (Hard to describe in words... But go look under there. ) Couplers may change from year to year, but this works like a charm on ours!
  • Dalehelman
    edited June 2017
    There is no adjustment nut on the NuCamp hitch.
    1. Hash  T@B Fun
  • 2Cougs
    It is not really a nut...just a piece of metal that we need to push down before the coupler will pull the rest of the way over the ball.
  • TTTab
    TTTab Member Posts: 100
    I was going to add silicone spray to my Amazon cart.  There are so many kinds and different types.  Please tell me which type, wet or dry, and what brand you would buy.  Thanks
    2015 T@B M@x S silver and white
    tv 2010 Lexus RX350 Matador red
  • Homebodyatheart
    @TTTab I buy the stuff in the spray can. I'm not home so I'm not sure of the brand. I've had a couple and I know one is liquid wrench brand. I use it on our garage doors twice a year to keep them rolling up and down smoothly. It also works well on squeaky bike parts and wet suit zippers as I believe it does not degrade the neoprene. Anyway, good stuff!
  • TTTab
    Thanks @Homebodyatheart  I have been out of commission and am trying to get everything into my cart to be ready to head out as soon as I am able.  Living vicariously thru all of you is helping me to plan for being able to take off later this summer.  My goal is to be in Fort Townsend WA in Sept.
  • 2Cougs
    @TTTab- I hope you make it to Ft Townsend!  We will be there... our first T@b campout.
  • 2Cougs
    This is looking under the hitch and shows the lever I am talking about.  By fiddling with it the coupler comes over the ball MUCH easier.  Thank goodness for cell phone cameras... just point the direction you want to take the picture and you don't have to get on your hands and knees!!! :o
  • ericnliz
    Ha, ah, Ha! =)
  • Dogden
    Dogden Member Posts: 6
    TTTab--- Fort Townsend... me too and I don't even have delivery yet!
