Refrigerator buttons
sbhtennis
Member Posts: 69
I believe that the button furthest on the right on my Norco frig is a Fan Switch. When should that be used?
If the fridge is turned on, so is the fan, unless you're camping in the cold and can benefit from the heat instead of exhausting itJohn, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
sbhtennis - that switch on my 2016 powered the auxiliary fan behind the white plastic grill next to the cabin door. The purpose of this fan is to provide more air movement in the cabinet the frig sits. Mine did not go on when the frig ran - you had to manually hit the switch. See Noisy Norcold for pics and more info.2016 Outback 320
@sbhtennis, Tabaz is correct. When we turn on the fridge, we also manually hit the button for the auxiliary fan. Perhaps a newer T@B doesn't need or has a fan which comes on automatically, ours was built in January of 2015.John, Judi, Guinness & OD in PDX
Here is a direct link to the "Noisy Norcold" thread...
http://tab-rv.vanillaforums.com/discussion/2635/noisy-norcold/p1
Towed by 2014 Touareg TDi -
THANKS EVERYONE
- 916 Introductions
- 72 Teardrop Groups & Links
