LED Light Bulb Access
JohnDanielsCPA
Member Posts: 238
How do you access the light bulbs in the bathroom and main cabin? Do they just pull out? Unscrew? I tried to access these and was met with significant resistance (unscrewing and pulling) and I don't want to break them. I want to replace my extremely bright light bulbs with something much softer.
2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed
I can't answer your question but if you find (or have found) a soft white version of the bathroom light, I would like information. I have found the soft white versions on the fixture over the sink/cooktop and for the reading lights in back but not for the shower.2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX
We bought from Costco battery operated stick on lights , 6 lights, that have a small remote control that turns them all on and off and dims the lights. AA batteries to operate. And you stick them where you need to. Works great.
@JohnDanielsCPA, the silver ring (and lens) around the main cabin light unscrews from the fixture. The LED strip is visible when the ring and lens is removed. I haven't tried the bathroom fixture.
Thanks Verna! If I can figure out the bathroom fixture, I'll post it here.2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed -
I need to replace bulb in one of the reading light fixtures on the wall by the bed. Please help. Where do you find them?
Actually, the main cabin light’s silver retainer ring just pries off. The light fixture can then be removed by removing the screws.2022 T@B 400 BD
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
