 DurangoTaB
                    Member Posts: 754
DurangoTaB
                    Member Posts: 754
            "The installation look good and as for the dust and moisture, we have not had any issue but then again I think so far all of them had the underbelly protector on, you could make a some kind of dust shield."
J.D. & Sue
http://www.homedepot.com/p/Plaskolite-18-in-x-24-in-Corrugated-Plastic-Sheet-1TW1824A/202043334
J.D. & Sue
Goes where it's towed to by 2017 Subaru Outback
2016 Jeep Cherokee & 2017 T@B Outback
1. They sent the material precut to the 49-1/2" width, but 6ft long...seems I only need 39-1/2" to go from the front cross member to the rear angle under the axle...correct?
2. They sent a bunch of mixed length trim pieces, mostly 3ft, some 2ft, and one 6in....also two 3ft long aluminum angle 'iron' pieces...any thoughts on why the odd mix?
3. Nice to get stainless hex-head self-tapping screws, but they also sent six 1-1/2" fender washers...?
4. One of the pix under "Alde Freight Train" (p.5) showed a LOT of dust on top of this cover. It appears the forward gap, above the axle, still lets in dust. Does anyone close that gap with "underbelly" material?
J.D. & Sue
Hi J.D. from Durango, I read your forum entry and would like to order the same kit that you did. We have a 2015 Max-S also. Could you list the part number/numbers that you ordered the parts under. Thanks
Gary
Rockford, IL 2015 Max_S
J.D. & Sue
J.D. & Sue
I'll try, although we have had nothing but rain the last couple days and it is really wet underneath!
On my Outback there is two intermediate aluminum cross members that keep the corrugated plastic from sagging in the middle - the angle iron L pieces you mention in question #2. These sit in the frame channel and are attached with one screw on each side.
These cross members span side to side, and there are three screws with large washers that go through the corrugated plastic sheeting and into the aluminum cross member.
J.D. & Sue
Ok, I crawled underneath to check it out. Yeah, got a little wet!
Start at the rear:
the 48 1/2" piece goes on the rear frame crossmember, side to side.
One of the aluminum angle brackets is located 19-20" from the back edge of the rear crossmember. Three hex head screws and a large washer are used to attach the liner to the angle bracket.
The two 50" pieces go from the rear crossmember forward, one on each side. These follow the contour of the frame rails. Finish each side forward with one 25" piece.
The other aluminum angle bracket is place just forward of the fresh water drain valve, approximately 6-8". Same hex screws and large washers are used. Sorry, it was tough to measure as the frame curves.
The 22" piece goes on the passenger side front edge (side to side), and stops at the black tank drain pipe.
The 5" piece finishes the front edge on the other side of the black tank drain pipe.
Hope this helps!
so much from the more Western Slope...
J.D. & Sue
Glad to help, let me know if you need any clarifications.
We have a trailer guy, who used to be next to the T@B dealer (now gone), who's supposed to be pretty good. I'm going to take this mess to him and maybe he can make some suggestions (like just boxing in the new regulator?). If I install the new underbelly I will definitely have a problem with my A/C condensate drain, and possibly create a problem for the under-body Norcold vent. I'm also a little worried about any propane leaks underneath (lines, connections, or the new valve)...they'll be boxed in. If that Norcold is running on propane (i.e. flame/ignition) it could be ugly.
J.D. & Sue
J.D. & Sue
I installed the cover just over the new regulator. It's 12" long (front-back) and 28" wide, fitting between the the right channel and the side of the gray water tank. The rear of the plastic is held to the cross member by self tapping screws, with black silicone underneath. I didn't seal the middle section so it can act as a low point vent for any vented propane (and facing backwards it shouldn't let too much dust or water in). The front of the plastic is held to the underside plywood with wood screws, aluminum trim, and polyurethane Liquid Nails. On the side next to the gray water tank I cut out 2 teardrop shaped pieces of 1-1/2" pink rigid foam to close the gap; it's wedged under the rear cross member and poly-LN glued to the bottom...pretty tight fit.
I hope this helps anyone with similar problems! Any questions, please feel free to ask...
J.D. & Sue
J.D. & Sue
