Brought T@b home from storage, de-winterized her, drained the anti-freeze, filled the tank a couple of times and drained, then sanitized the tank and lines. The hardest thing was getting the battery box cover off!! I had to move the propane tank to get to the release tab and that was only after crawling underneath. The band that holds the propane tank secure is right next to the release tab; huge pain in the butt Glad I stuck with I thought, all six holes needed water, some more than others. I also installed my new port hole cover and took a couple of pics. It looks and works great, and although the price was a bit high, it really is rather ingenious how it works. I also took a pic of the faucet head I put on last fall. It was the one Neil posted a pic of on the old site after a discussion of how hard it was to keep water from getting behind the sink since the faucet does not extend far enough away. I got it at Walmart and it works great; getting water behind the sink is no longer an issue. Come Sat. all I will have to load is food, clothes, kayak and bike and spend 3 nights camping on Beaver Lake in NW AR! So excited for my first 2014 trip.
Jbug -- Oh, SUPER, I am energized by all you have done! I'll be doing the same Easter weekend. A couple of questions for you -- did you add the water to your battery yourself or take it somewhere for service? Also, as I understand it, you just replaced the water head on the faucet, not the entire faucet; correct? It looks as though the new one swivels outward, directing the flow more into the sink than straight downward. Do you have a part number from Walmart for that?
I'm excited for you and I hope you have a wonderful trip!
=D>Same problem with the battery box cover. I took a Dremel tool and ground the notch off the one next to the LP tank. It still goes down into the slot, but no longer snaps so that I don't have to fight the tank to push it in to remove it. Don't figure I really need the snap on both sides since the strap holds the lid in place anyway.
The port hole cover looks great, and I'm sure it's awesome. I haven't ordered one yet, but I found some round cake boards at Wally World that were almost the right size. I glued them all together (three of them) then ground them down to fit the hole. I put a pull handle on it by drilling two holes about six inches apart at the center then running a cord through and tying a knot on each end so they wouldn't slip through the holes. I also reinforced the holes by gluing washings on each side of the holes. Works great, and the boards were already decorated. Every time I go to a store somewhere I'm always looking for something that I might use for the T@B, and these cake boards just seemed to say, "Aha, you know what I could be used for."
L-)Larry & Booger - 2013 T@B, 2012 GMC Sierra
Happy Trails Y'all
Beth, I tackled the battery all by myself!
Getting to the battery was the hard part; I have skinned up knuckles to prove it. I had watched a You Tube video on how to add water, and how much, so it was easy. And yes, it is a faucet head that swivels out. I don't have a model #, but I just looked for the one like Neil had posted.
Larry, I had planned on only snapping down one side of the battery cover too, but I discovered that the other side would not snap down unless the other was snapped down too. I was afraid to just depend on the straps to keep it all secured. Also great idea for a port hole cover!
