what to look for on used purchase
aquamous
Member Posts: 6
i have an opportunity to buy a 2010 T@B. it has been stored inside since being purchased and not used (or very minimally). What concerns would you suggest I have and what "inspections" should be performed
Sounds like it is a good find because it has been stored inside and protected from the weather.
Start at the top and run a water test across the roof, make sure there are no obvious leaks. Push on the walls (not too hard) and make sure there is minimal give. Push on the floors, especially around the entry, looking for any excessive give as well.
Run water through it and look for leaks, as well as put some water in fresh tank and check the water pump.
Make sure all the systems work, refrigerator, stove, sink, and any extras.
Don't worry too much about the tires, just make sure they can get you home, if you purchase this unit you will be replacing the tires at that age anyway.
Sterling, VA1 -
thanks for the response and suggestions0
@aquamous, I don't know if you read this post by @FishDoctor, but their list might be a good one for you to use in checking out a used T@B too, not just a new T@B. At least you could glean some ideas!
FishDoctor Posts: 2MemberBy the way, I thought I would provide a copy of the list we developed for our walk-through with the dealer when we picked up our T@B. Many of the items were gleaned from discussions on this site. I thought other prospective T@bbers might find it useful...Trailer Walkthrough List.pdf 425.8KJohn, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner2 -
looks like an excellent tool. I saved it. Thanks0
