Emergency Start for Alde
Deltaboy59
Member Posts: 315
While browsing the Alde manual, I came across this procedure to bypass the control panel in an emergency to turn on heat at furnace without thermostat control.
It specifically references a jumper to do this.
Im a rookie, other than my personal experience with the Alde, which I am very pleased with. Trying to learn as much as I can about it.
Anyone have one of these parts?
Have you ever tried this procedure?
Could you fabricate a DIY one?
Years ago computer hard drives had jumpers - you had to jump differently for different makes of hard drives for different computers or if it was the startup drive vs a backup, etc. so I imagine it's similar.
You could make a jumper if you could get a connector that matched up. You just put a piece of electrical wire in the right slots - jump those two like the diagram shows. You could probably just stick wire in but the plug keeps it together.
While troubleshooting what turned out to be a thermostat problem, Ed K instructed us to use an electrical wire to connect the appropriate slots just as PXLated suggested. It worked well!Steve and Karen Cullowhee, North Carolina 2008 Ford F150 --2018 T@B 4001
Useful information... From real world experience... Will stock a piece of jumper wire for emergencies...1
