Water tank cap
KTOT
Member Posts: 35
I think I read something somewhere on this topic but I don't remember what or where and cannot find it again. Can the opening the fill the water tank on a T@b S Max Outback (2017) be replaced with this hose connection cap? I greatly prefer hooking a hose up to fill an RV water tank over the way the T@b has to be filled now, with a hose just set in, not connected. If it will work, is there any reason not to replace the existing with this? https://www.amazon.com/gp/product/B000BGM240/ref=ox_sc_act_title_2?smid=AVY0SA2VSFK9N&psc=1
Check out this post:
http://tab-rv.vanillacommunity.com/discussion/1398/new-fresh-water-fill/p1
Some good info about replacing the stock fresh water tank fill port.Jon & Angela | Florissant Colorado | 2017 Outback S -
@KTOT, here you go. http://tab-rv.vanillaforums.com/discussion/4671/replacing-the-gravity-water-fill
Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner -
Thanks to you both for the links. I'll check them out.
Yes, I replaced the original with the one in ColoradoJon's link. It works great, but you still have to put a hose or tubing in the hole for filling. I love it as it is much more durable and easier to use than the original (not knocking the original, just personal preference).Verna, Columbus, IN
- 916 Introductions
- 72 Teardrop Groups & Links
