what is pressure capacity of the aluminum wheels on 2016 CS-S
TabneroTabnero Member Posts: 252
the reason I am asking, is because Goodyear has new trailer tire. The endurance for ST205/75R14. But it is a load range D and max inflation of 60psi. So if any one knows the wheel pressure capacity that would be great. I like the idea of these tires with a higher speed rating. Trying to determine if I will need heavy duty stems as well. Any help is appreciated
    @Tabnero, The alloy aluminum wheels will handle the tires just fine. With the D load range, you're going to want to not go below 45 psi to accommodate the sidewall of the D load range. You could start at about 50 psi, and adjust for the bounce of your trailer, but I personally wouldn't go any higher than that. If you're worried about the valve stems, you could have metal ones installed when the tires are changed out. Just make sure the tire folks use the ones with the GOOD heavy duty rubber grommet required for using the metal ones. Hope that answers your question, if not, ask away! :)
    You're welcome. Let us know how you like your new T@B shoes! :)
  • TabneroTabnero Member Posts: 252
    may move over to Task master load range C, just do not need that much capacity in a tire. They weigh 3 pounds more per tire as well
