gilbutler
                    Member Posts: 169
            Since I’ve received so much good information from this forum, I’ll suppress my embarrassment and post my last T@B trip experience for anyone who didn’t pay much more attention to page 4 of the WFCO Power Center manual than I did.
We spent our first night at Van Damme State Park, below Mendocino, California. Then we went to Patrick’s Point State Park, above Eureka, California, for two nights before
Heading toward Coos Bay, Oregon. Because of the weather, we turned back to Turtle Rock RV Resort at Gold Beach, Oregon, for two nights. This was our first location with water and electric service. The following is the sequence of events, but I didn’t put it together until after I returned home.
Having not camped with city water hookup before, Cathy turned the water pump on, and turned it off when she heard it go a bit wild. That night, we decided to watch a movie for the first time in our T@B. The picture was a bit strange and when the DVD stopped, I checked the voltage and was surprised by the low voltage (11.3V on the 12V outlet). When I connected the tow vehicle at idle, the voltage went to just over 14V, but when I hooked to my (new) generator instead, the voltage returned to about 11.3V. After returning home at night, I disconnected the tow vehicle, turned everything off that could be switched off, and pulled the battery fuse. In the morning, I started trouble shooting by checking the battery and was surprised to find it at a healthy 13.6V. After connecting to my house 110AC, the T@B 12V system indicated 13.7V. After re-reading page 4 of the WFCO manual, I realized that running the water pump while connected to city water must have created an overload detected by the Power Center, which then went to fold back or shut down. When I pulled the battery fuse and disconnected all power inputs (for the first time) after returning home, the Power Center was allowed to reset, returning the systems to normal.
Happy Trails Y'all
Following is the technical explanation Michigan Mike gave me when I was asking similar questions earlier. I don't really understand it, but what I did get (along with the rest of the discussion) is that 13.6 Volts is normal when connected to shore power. Remember that the battery is a 12V battery, so anything over that means that it is fully, or almost fully, charged. Your 12.5V would indicate a fully charged battery. If after charging, and nothing is on (including the little lights on your TV, stereo, etc.) and your voltage continues to drop and fail to again fully charge, I would check the fluid levels in the battery. Pry off the cell covers (wearing gloves and eye protection) to see if the fluid is about 1/4 inch from the top. If not, fill to that level with DISTILLED water. I would also disconnect the cables and push them out of the way while doing this just to be sure you don't short them across accidently. Oh, and be sure to mark the cables so you'll know which post to reconnect them to.
Technically speaking Larry, the electric converter converts the 120 VAC 60 Hz from the outlet to 120 VDC after it passes through Diode Rectifier #1, the Capacitor then filters the ripple voltage. This 120 VDC voltage is then fed to an Electronic Switching Circuit that converts it back to AC and increases the frequency from the original 60 Hz to 3,500 HZ. This high frequency AC voltage is then fed to a step-down transformer where the output voltage is reduced to approximately 13.6 volts AC and Diode Rectifier #2 converts the AC to 13.6 Volts DC and the Capacitor filters out the ripple.
" alt=">:)" height="20" />
Happy Trails Y'all
Happy Trails Y'all
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
Irregardless of the above, a battery DOES lose a charge over time when sitting idle and not attached to any load, so battery drain does occur and is a normal phenomenon. Cold weather will impact a battery and hot weather is tough on batteries too.
