Trailer tongue jack scraping on driveway dip
dmerzbac
Member Posts: 289
For those of you who have dips in your driveway, how do you keep from grinding your tongue jack into the concrete (or other material)? I've tried 2x4's in the dip to raise the hitch some and driven at an angle leaving the driveway, but the jack post still grinds into the concrete. Is there something that will cover the end of the post to keep from damaging it?
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
dmerzbac, check out my post " trailer jack in the way of my tailgate" I made this removable jack adaptor so I could open the tailgate on my Jeep. I think it would also solve your problem as well. Check it out and let me know if you have any questions.
Thanks, Shawn
I bought Pop-Tab's removable tongue jack about a year ago. Very easy to remove and install. Would not go boondocking without it. Very well made product.2016 Outback 320
I had a real problem with my 2016 Kia Sorento and it was my hitch that was dragging and I don't even have much of a transition. I had to use airbags in my coil springs to raise it up and that allowed me to lower my ball hitch. However, I haven't had much trouble with the jack scraping. You could use this device the http://jack-e-up.com/ which will allow you to easily remove it completely. Also, if you don't want that expense, it comes off with three bolts. It is really easy to remove and without it, you won't have any clearance problems at all. I'm guessing it takes less than 5 minutes to take it off or put it on by removing the bolts. That's what I had to do at Tabazona 2017, when I took my 5 wide there, before we had the Tab. It was not a big deal at all.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0
I bought POP-T@B's adapter. It is well-built and would solve your problem.2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed0 -
Sorry, I should have indicated it is available at the Teardrop store.
2022 T@B 400 BD
You need to search "removable jack plate."2016 Outback 320
if you go to the teardrop shop website, go to the main menu, then to the tab " outside your teardrop" its the 5th item listed on the page0
I modified the complet tongue and jack area to take care of jack height and TV rear hatch and door opening.
you see the original lenght of the tongue and the original height of the jack.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Les Escoumins and Petite-Riviere-St-Francois QC0
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
