What type of glue do you use on varnish wood?
Clopidogrel
Member Posts: 33
I try silicon but it doesn't stick to the wall.
What are you trying to glue?2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
At first, I try to add a tablet in the empty space behind the toilet, but it fall on the floor. Small piece stay in place. I use lego plate to hold my key and silicon is good enough.0
@Clopidogrel, well, here's a thread titled screw or glue with a vote for command strips! We use them at home on wood and wallpaper, move them around without ill effects, etc. This thread also includes some good photos of construction details. I also use museum putty at home for items I want to stay in place on horizontal surfaces and know that's been mentioned on the forum. Command also makes strips for use in wet areas. There are other caveats re weight, ambient temperature etc.
http://tab-rv.vanillaforums.com/discussion/4887/screw-or-glue
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner1
- 421 Service/Maintenance & Recall Notices
