Is there supposed to be a fan in this hole?
[Deleted User]
Hi, my fridge puts out a tremendous amount of heat (just ordered the auxiliary fan yesterday) and while I was looking at the fridge configuration yesterday I saw this big hole cut out just below the fridge coils that leads to the vent hole in that bottom cabinet at the front door. Is there supposed to be a fan in that hole to draw the heat down to the vent in the floor? or...is the hole just there to let the air escape? its not a very efficient way to do it since heat rises. There is a small fan about mid-way in the coils, but it seems like there should be one in this hole.
That goes up and out the vents on the front of the T@B...that's the inlet
J.D. & Sue
Agree with Durango -that's the air inlet. You should also see a fresh air opening in the floor itself near that hole. Check out Noisy Norcold for more pics and info about fans.2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
There are also comments about dirt possibly coming in through the floor vent here:
http://tab-rv.vanillaforums.com/discussion/4956/dirt-inside-t-b
T@B trip wherever
New surprises everyday
See beautiful world1
- 956 Air Conditioning & Refrigeration
- 921 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
