Tail light flickering
Wil
Member Posts: 26
One of my tail lights is flickering... I am wondering if there is a loose connection rather than a faulty bulb (?) - I wish my electrical engineer hubby was here. Any suggestions? What kind of bulb is used if I need to order one to replace it?
Thanks in advance!
Wil
Thanks in advance!
Wil
2015 T@BM@x-S "Clementine"
Honda Pilot, Austin TX
Wil, Kevin and Jack, the Bernese Mountain Dog
If there is no loose connection, the entire tail light assembly will need to be replaced as all of the LED bulbs is one unit. Elsie in Parts at nüCamp can order you a new tail light assembly.
Early T@Bs starting around 2014 were not LEDs. Probably just a dirty or loose confection.
- Hash T@B Fun
@Dalehelman, my early 2014 has and had LED brake lights. Maybe prior to 2012 didn't have LED's.
@Wil has a 2015 model with LED brake lights.Verna, Columbus, IN
Made it to the coast safely - luckily it is my right light so I could at least could signal left... which seems a more dangerous turn. I will pretend I know what I am doing tomorrow! Thanks for the info!2015 T@BM@x-S "Clementine"
Wil, Kevin and Jack, the Bernese Mountain Dog -
Is it the tail light or the brake light or both? It may just be the 7pin plug. Try wiggling it around and see what happens.
- Hash T@B Fun
Just the tail light. I'll try that! Thinking about it - I think that may be the problem as it was pulled out inadvertantly as a certain person who shall not be named unhitched the trailer and drove off without unplugging the trailer
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
