My 2018 320 does not have it, but as previously stated, the fellow I spoke to aluded to the fact that he got one installed on his. Not sure who installed it though(key point missed!! Lol)skwhee said:To our knowledge, it is standard in the 400 model. We are not aware of it being standard in the 320s but nüCamp is always improving.
Correct. What you see on the roof is the fan vent for the AC.4ncar said:I trust that is the vent...I believe on the 2018s the vent is on the roof...I'll be checking this when I get home...
Here it is. It does not seal tight so it can still vent.ChanW said:@Dalehelman! You never stop with this stuff, do you?
What is the cover you've used actually made for?
Dalehelman said:Here it is. It does not seal tight so it can still vent.ChanW said:@Dalehelman! You never stop with this stuff, do you?
http://low.es/2qLH79N
I am a little confused with this Y fitted set up...? Why or when would you ever be connected to city water & to the black tank "flush" port(aka vent? I would do this only at the sanity dump during my flush process...Dalehelman said:Their is a vacuum brake on the hose, and it is not the hose I use for fresh water.
Haha, it's not a disappointment at all! Serendipitously, we actually discovered the black tank flush on Wednesday during the walkthrough while taking delivery that our new 400. Was going to update here in the forum, but you beat me to it.skwhee said:@Justin_in_Seattle
Hope this is not a disappointment, but you can cross Black Tank Flush installation off your Things to Do list. This feature comes standard on the 400!
merakano said:
@Dalehelman, it looks like the vent line runs almost horizontal and connected to both black and gray tanks. How would I know if the fresh water hose entered to the blank tank's vent line? I would like to copy your ingenious method if I can but worrying about water leak inside T@B. Could you explain more detail?
Correct no problem as it allows flushing and rinsing of both tanks.4ncar said:merakano said:
By this photo, it would more then likely go into both, black tank mainly being that's the first Y fitting...my guess..
The more the merrier Dale!
