Torque specs for T@B 320
System
Administrator Posts: 192
This discussion was created from comments split from: What is the proper torque spec for the lug nuts on the 400?.
I keep mine torqued between 80-90 lbs. And SKIP the anti-seize compound--it's likely you will over-torque them. (see this) Since our wheels are aluminum, It's also a good idea to re-torque them again after a couple hundred miles, and that should keep them tight until the next time you remove your wheels. Since the aluminum rim expands/contracts at a different rate than the steel hub / bolts, they benefit from this extra step.
Speaking of aluminum with steel...
My neighbor recently reminded me (with a grand amount of pounding and cussing) that the galvanic action that happens between steel and aluminum (especially with salted highways) can weld the aluminum wheels to the steel hubs. Might want to apply a dielectric grease between there.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
It seems my comments and advice to you all here yesterday was mistakenly removed or moved by the moderators, since I own a 320 model perhaps?
In any case, there is no difference between torque specs on a 320 or 400 model, especially since many variations share the same axles. This goes for almost all lightweight towable chassis (utility, RV, etc). The specs are 90-120 ft lbs for T@b 320/400, and 75-85 for the 13" wheels on the T@g. This is according to the axle manufacturers.
I'll repeat some important advice-- Avoid using anti-seize compound on your lugs as this will cause you to over torque them. Also, since we have aluminum rims, te-torque them again after a couple hundred miles, just once more, as the expansion rate of the aluminum rim against the steel hub and lug bolts can loosen them up on rare cases. Better safe than sorry!
2 -
wizard yes you are correct, putting any kind of oil or grease on a bolt makes it a wet torque which is different than a dry torque. Even my 1999 Jeep Wrangler wheels use the same torque as the Tabs. I find that 100 foot pounds is just about right in the middle. After owning a diesel repair garage for 31 years I will say if you just check to see if they are lose once in a while you would be way ahead of the game. We could debate the EXACT proper torque till the cows come home. If you see any dark powder near the bolts they are probably lose. Art2019 TaB 320 S Boondock Edge2
Guess I'm the only one to disagree about anti-seize. I have put it on every threaded item I've encountered for well over 50 years. I have experienced excellent results, and never seen a problem using it.Stancil Campbell
2011 T@B
Rockingham, NC
2 -
I am not against anti-seize just suggest you look up the wet torque for the bolt you are using as the wet torque will be less that the dry torque for the same bolt. Art2019 TaB 320 S Boondock Edge0
There are always different opinions on what to use. We can leave it at that, please.Verna, Columbus, IN
Eric aka: Lone Wolf0
