Unfortunately I keep the trailer in a storage facility that is a fair distance away, so I don't have a way to take a photo.ChanW said:The hose we use has a collar on the end fitting that tightens around the hose with a ratchet kind of locking mechanism. It might have loosened up?
Can you post a picture?
Are these lug/bayonet fittings standard across all manufacturers (e.g. Valterra, Camco) or do I need to be sure to buy the correct brand?RollingBnB said:Check inside the elbow end for the rubber ring. It might of fallen out in which case it's time for a new elbow.
https://www.youtube.com/watch?v=eHtY97oD_-oMarceline said:Are these lug/bayonet fittings standard across all manufacturers (e.g. Valterra, Camco) or do I need to be sure to buy the correct brand?RollingBnB said:Check inside the elbow end for the rubber ring. It might of fallen out in which case it's time for a new elbow.
X2RollingBnB said:Check inside the elbow end for the rubber ring. It might of fallen out in which case it's time for a new elbow.
Thanks for the suggestion. I'm not sure if this is the solution but it seems probable so I just ordered a set of replacement gaskets.RollingBnB said:Check inside the elbow end for the rubber ring. It might of fallen out in which case it's time for a new elbow.
