How long can I run heater on battery?
blackc2004
Member Posts: 117
Hello all,
I'm wondering how long will the ALDE system heat the T@B while running on propane and battery power? I've only ever used it while hooked up to shore power.
Assuming you have a full tank of propane, fully charged regular battery (80 Ah), you don’t have solar, you don’t use electric for much else (the battery will go WAY before the propane), that it doesn’t get too cold outside ((say 30’s), and you don’t heat it inside to 85degrees...IMHO...3 days.
J.D. & Sue
I have propane and new fully charged battery, but no heat or hot water.0
Check the recent thread....
http://tab-rv.vanillaforums.com/discussion/6042/no-hot-water-or-heat-on-2013-t-b#latest
J.D. & Sue
