https://www.youtube.com/watch?v=WzW1kK8oWkc
Estancio said:They really take very little grease!
Took almost 1/2 tube the first time for me, on each hub.rkj__ said:Except the first time you use the EZ Lube method. It seems that from the factory, the channel between the front and rear bearing is not filled with grease. So, it takes a ton of pumps on a grease gun to fill that cavity. After that cavity is filled, then you get grease flow with every pump.
