On a T@B 400, factory installed inverter outlet, while testing the outlets in my new 400, I found that the inverter outlet is indicating an "open ground" per the plug in tester I have. All of the other outlets are OK.
Wondering if the inverter outlet is intentionally connected this way or this is an issue that needed to be corrected by NuCamp/Dealer?
Utah Driven
2019 T@B 400 (Ex 2018 400)
2015 MB GLK 250 Diesel
2018 GMC Canyon Denali Duramax CCSB
0 ·
Have you tried plugging an item into the inverter using the inverter powered from the battery? I'll bet everything is fine.
No difference in the indicated "Open Ground" from Battery/Solar charging or shore power.
I was also guessing a floating ground, just not sure if that is a correct "assumption" on my part or not.
Utah Driven
Plug in a 110V item like a light or something comparable and verify that the inverter actually works. And do a search on Google too and you will see that this is common and that the inverter is fine.
There should be only 1 neutral/ground bonding. Since there is an inverter and shore power, only 1 should have that bond when active.
Tomorrow I will check the ground path from the shore power plugs to trailer ground vs battery ground to the inverter plug, then check battery ground to trailer ground, which as I gather should be an open other than for trailer-TV lights, turn/stop and brake.
But that brings up the thought trailer ground should be 12VDC ground also. Since the inverter/solar/shore power can be active at the same time in a parked-shore power situation, but battery should be separate from shore power bond. Hmmm, wondering now if that is why some have notice blown fuses?
Utah Driven
https://www.microair.net/products/generator-bonding-plug?variant=12272654155860
Considering a 2023 TaB 400 with the full Lithium option,
2022 Jeep Gladiator High Altitude, Tow Package.
