fuse problem
Hello, I'v had my 2014 T@b-S for a few days and was hoping to take it out this weekend, but I think I blew a fuse.  At the converter box, F3 has a red light next to it.
I had put a tire inflator into the 12V receptacle in my T@b to see if it would work, for future reference.  Um, apparently not.  I lost all lights and radio.  I plugged into power to see if perhaps the battery had died, but after an hour that made no difference, and then I noticed the red light.
So is this likely a blown fuse and it appears as I look through the files that it's an 10 Amp ATC Blade Fuse.  Can I replace with https://www.amazon.com/Bussmann-VP-ATC-10-Acting-Blade/dp/B000AZ3APC or do I need a higher grade and where would I get that?
Anything else to consider (besides not plugging high-power items into my 12V outlet?)?
Thanks!
