jhouston
Member Posts: 24
This is an alternative to buying those green 1lb bottles of propane and a great way to free up storage. The 5lb tank will hold an equivalent to 5 one pound bottles and is much cheaper to fill in the long run. It cost me $3.00 to this tank. The bracket mount and clamps are sold separately. They aren't cheap but will last forever. The small clamps only reduce to 1.5 inches in diameter so I had to get extra shims from the manufacturer to get the diameter down to 1inch for mounting. It holds solid. Hook you up a hose to a camp stove and grill and your good to go.
@pthomas745 Ha Yes! Although it's a DOT approved Tank!
