I'm now intrigued by this combination. Sounds like an excellent fit on paper. Share any real life experience if you would, please. Florida RV Super Show in town this weekend. Thanks!
2019 T@B 400 Silver/Black
2018 Chevy Colorado Z71 Duramax oil burner
Tampa, Florida
0 ·
Tampa, Florida
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
2017 T@b 320 S
2017 Kia Sorento SXL AWD
WilliamA
2017 T@G XL
WilliamA
2017 T@G XL
A few thoughts on the Frontal Area discussion:
1. Frontal Area [FA] is the total area in square feet of the tow vehicle and trailer exposed to air resistance. That statement or something like it is in most automobile manufacturer towing guides.
2. FORD is the only manufacturer that seems to publish FA limits yearly. I would guess more manufactures will do so as they comply with the SAE J29807 Recommended Practice guidelines for testing/marketing vehicle towing capability.
3. Recommended FA in general goes up with vehicle size and power.
Little cars = car only FA
Escape size range = 30 sq-ft (base vehicle is 20 sq-ft) [2003 data]
Next size (like Flex) = 40 sq-ft
Many SUV and mid-size pick-ups = 50 to 55 sq-ft
Full size pickups = 60 or more sq-ft
4. It is my understanding that FA is a vehicle performance issue more than a vehicle breakdown or safety issue. If you exceed your vehicle GVW, Axle Weights, CGVW, Trailer GVW, Tongue weight you will at best shorten the tow vehicle useful life while increasing your repair costs. Worse case overloading could cause an equipment failure and highway accident.
That I believe is not the case with FA.
Exceed FA recommendations and you could be spending even more on gas/fuel while towing, could have transmission heating problems, and will most likely drive with the vehicle feeling slow & under powered. How much an individual driver, vehicle, and trailer see these impacts will vary and be effected by many factors - - - driving style, speed, terrain, weather, etc
Years ago I towed a sailboat that was small and well sized for my tow vehicle with no issues. For the next larger sailboat the tow vehicle was not correctly matched and towing became a chore. One reason I have a T@B 320 S on order is to insure the trailer is well below all my tow vehicle limits and recommendations. I want my RV'ing travel to be a fun adventure not a chore.
The first time we towed, we had a bit of porpoising, but installing sway control took care of that.
Last fall, we towed through NM and Colorado, including Wolf Creek Pass. There’s a sweet little feature on the Escape that automatically reduces rpm when the engine temp gets too high, and that kicked in once on the way up the pass.
Other than that, the Escape / Outback combo has been a breeze.
Richmond, MI
2019 T@B 320 S
