Disposal Of Anti Freeze
How are people disposing of the RV anti freeze after de-winterizing?
2018 T@B 400 - 2017 Chevy Colorado
    @newbie, the pink anti-freeze is listed as non-toxic, so after most of the stuff is flushed from the sink, shower and toilet traps, it ends up in your black and gray tanks. That is emptied when you drain the tanks the next time, and it is listed as ok for rv dump facilities. If you have it in the fresh water tank, you simply fill and let your tank drain several times until clear. Some people have drained the tank into buckets and then emptied into a dump facility. Some collect the flush water and put it down your home toilet. I have a neighbor with a larger rig  who drains his fresh water tank onto our city street and then flushes the street generously with a garden hose for an hour. I am not recommending any of these disposal methods, but have seen it done. Consider your local ordinances and the environment. I have never had the anti-freeze in my fresh water tank so have never had to worry about it. We just simply empty our gray and black tanks as normal into a dump station.
  • newbienewbie Member Posts: 30
    dragonsdofly - thanks for the info.  Think I'll empty the tanks first time out this year at a campground.
  • WillieontheRoadWillieontheRoad Member Posts: 34
    Newbie,
    Can't help you with disposal this year, but check out Mandy Lea's unconventional way to winterize drinking water for next year.  After the winter season you can invite your friends and have a party.
    https://www.youtube.com/watch?v=1bwB2XIGFYg
    2018 T@B 400  Jeep GC
    Alan & Joan Fisher
    Austin, TX
    Hmmmmm...... 11gallons of Fireball might be a little spendy though. =) But still...the thought remains.... :fearful::rofl:
    edited February 2018
    I may be wrong, but I think Mandy just adds enough Vodka to prime the faucets lines, shower and sink traps. If you add more, think of the fun you and your friends will have in the spring.
    Alan & Joan Fisher
    Austin, TX
  • FishDoctorFishDoctor Member Posts: 66
    But think how wonderful the cinnamon smell will be whenever you open the taps in your T@B!
    Downers Grove, IL
    2017 T@B S Max, Blue and Silver -- "The Blueb@rry"
    States Visited Map
    @FishDoctor, As long as it's cold, and keeps the cinnamon smell for brushin' yer teeth...who cares! =)
