Please as always perform to your technical level. I installed 2 92mm fans with small amount of stand  off to create some air movement directed at the fins creating the heat. Note the magnetic thermo switch it opens at 120 and closes at 90 very simple process the red wire from fans connect on one side other side is battery hot which you can tap from above the existing thermo switch. I left the factory switch and fan in position. I did add the 2 additional fans on side of unit so I have 4 fans connected to the magnetic switch it works perfect counter is no longer hot.
Note - I also made the the fans on vent side removable for simple fact there are 3 fuses located on top of fridge that can be reached without removing stove top.
Side view
Top of fridge
Sterling, VA
Like 8 bucks best part it has a magnet so it's attached to the part that generating all the heat
Central,Fl
2015 T@B Max-S
Central,Fl
2015 T@B Max-S
Well done!
Central,Fl
2015 T@B Max-S
