Air conditioner face dimensions
I have a favor to ask:
If it’s not too much trouble can someone reply with the dimensions of the face of the wall air conditioner unit in newer t@bs?
My T@b is in storage so I can’t get it myself.
I hardly ever use my AC and I like @MandyLea’s idea for using magnets to cover it with a piece of art.
  • Tabaz
    Tabaz Member Posts: 2,420
    Do you plan on removing the AC unit - or just want the overall dimensions?  With or without the wood trim that surrounds the opening?  The AC protrudes from the opening.  Do you also need that dimension?
  • Marceline
    Marceline Member Posts: 1,777
    I'm not planning to remove it. I just want to attach a piece of artwork to cover the front.
    So I really just need the dimensions of the front face of the AC unit.
    Fast forward to 8:18 in this video: https://mandyleaphoto.com/2017/02/23/18-camper-mods/
  • Tabaz
    OK, got it.  Will post the measurements for you later tonight if someone else doesn't beat me to it.
  • jgram2
    jgram2 Member Posts: 1,522
    The front of our fridgidaire is 11.5 x 16. There is a tiny setback on the bottom, so the actual front is more like 11.25. And our AC facing is plastic so magnets wouldn't work but Velcro "spots" would. There is nice wood framing around the box. Don't know if this helps. And sure, @Marceline, I'm able to fast forward thru mandylea's videos, not. She is such a delight. Judi
  • Tabaz
    The actual opening is 11.25" tall by 16" wide. There is a 1" wood frame surrounding the opening. So the overall dimensions with the frame are 13.25" tall by 18" wide.  My AC protrudes 1.25" from the wood frame at the highest location (the center of the AC unit at the bottom.  Agree with Judi - some white Velcro spots would work great and not be very noticeable with the artwork removed.
  • jgram2
    Photorealism!
