Clam shell galley tent with other accessories
Pieshobbithouse
Member Posts: 17
Has anyone tried to add the awning with the galley tent in place. Can the two be used together?
2018 CS-S
Can't see no reason why not. I have the XL awning and used it last season and have just purchased the galley tent for this season and intend to use both. Both awning and tent are Pahaque products and designed for the T@B.
I'm assuming when you refer to awning it is the Pahaque or a close faximily that is mounted on the side. -
It looks like i will loose one side of the attachment point where it intersects with the awning. But i guess that is ok according to pahaque. We were able to them .2018 CS-S
it works, also with side tent
I got to use the galley tent this week end and the tent has some serious problems the way it is made to connect to the trailer. I'm presently working with Pahaque to resolve these apparent problems. It is possible there was a problem when it was made for my order.
I was also under the impression this tent would be similar to the one depicted in the YouTube video. It is quite a bit different.
Hopefully we can resolve this problem with the connection to the trailer.
After that being said, I feel this tent is an absolute necessity for the CS-S. It is great to have a closed kitchen area and is large enough for two chairs and a small table. -
I have been using a CLAM traveler shelter and I'm working on a way to connect it to the trailer.Capt_KLR said:
http://stores.clamoutdoors.com/quick-set-by-clam/quickset-traveler-1676.html
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
