Used 2017 T@b S and recent cold snap. Newbie Concern
kyk4me
Member Posts: 3
Plan on buying a beautiful 2017 Tabitha in OK. This recent cold snap has me concern. How do I know if there is damage? I believe it has been hooked to city water. Would it be okay if heat is on?
Need more information ie. Low temps and for how long. Stored inside or outside.
- Hash T@B Fun
Have the owner put water while you are there, and wait a whille if water is spilling out from under and use all focet and thank. You will know.2017 T@G Max Outback "Le Refuge"
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Les Escoumins and Petite-Riviere-St-Francois QC0 -
What’s the best way to check the pump hose connections? And I wonder how the elbow leak at the fresh water outlet was revealed? Acknowledging there can be minor to major “froze” damage.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner0
- 417 Service/Maintenance & Recall Notices
