Used 2017 T@b S and recent cold snap. Newbie Concern
Plan on buying a beautiful 2017 Tabitha in OK. This recent cold snap has me concern. How do I know if there is damage? I believe it has been hooked to city water. Would it be okay if heat is on?
  • Dalehelman
    Need more information ie. Low temps and for how long. Stored inside or outside.
    1. Hash  T@B Fun
  • Luckyj
    Luckyj Member Posts: 286
    Have the owner put water while you are there, and wait a whille if water is spilling out from under and use all focet and thank.  You will know.
    TV 2005 jeep TJ unlimited
    Alaskan Malamuthe on board!
    Les Escoumins and Petite-Riviere-St-Francois QC
  • jgram2
    jgram2 Member Posts: 1,522
    What’s the best way to check the pump hose connections? And I wonder how the elbow leak at the fresh water outlet was revealed? Acknowledging there can be minor to major “froze” damage.
