ALDE Won't heat on shore power
dross
Member Posts: 5
Just bought my new T@B 400 four days ago. Did a test on the heating of the TT with propane and that went OK. However, when I try to heat with shore power only all I get is gurgling in the glycol tank. the heater itself is cold. I have replaced both of the fuses in the green sleeves on the ALDE heater itself. the fuses looked OK but were a little different from the original ones that seemed to have a beed or ball in the middle of the wire fuse, so I changed them. I don't know what else to do. The dealer has not returned my call yet. Manual is vague as to troubleshooting.
The Aldes in 320s are prone to coming unplugged. Check and make sure yours is plugged in, Maybe a 120v outlet somewhere near the Alde?John and Henrietta, Late 2016 T@B S Max in Western New York0
The gurgling sound is suspect of an air pocket somewhere. Do the hoses get warm?2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
Checked the AC plug and it is good. The hoses get warm on propane, but not on A/C. I have tried the up/down of the jack to try to dislodge any air bubbles.0
It’s hard to imagine air bubbles would be a problem on electric and not on propane.
Check the circuit breakers in the converter and check the GFCI. And, you are plugged into shore power, right?
In the upper right corner of your Alde control panel, is there a little icon that looks like an electric plug?John and Henrietta, Late 2016 T@B S Max in Western New York0 -
Please use an electric hair dryer or something that plugs into an electrical outlet to verify there is electrical power at the Alde electric plug. If no electrical power, check for a blown circuit breaker in the converter below the closet door.
Please check the level of the glycol in the reservoir tank in the closet. It should be between the min/max line. The lower the level of the glycol in the reservoir, the more it gurgles.Verna, Columbus, IN
If you are at home and plugged into a 15 amp house plug you could of popped the breaker in the house. Alde on high plus converter draws over 15 amps
2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
Thanks everyone. I am probably impatient on this one. The system works but very slow in heating up. I believe now that it may be using only one of the heating elements due to the limited 15 amp plug I am using. It took about 6 hours to heat up to 60 degrees. It helped when I started it using both propane and A/C. So I will wait until I plug into 30 amp service. Appreciate all the help from you fellow tabers1
Well, at least you know some of the things to check if you do run into problems!John and Henrietta, Late 2016 T@B S Max in Western New York2
X2 The gurgling comes from the circulating pump that runs on 12 volts the heating element needs 110 volts. Test the outlet for power as Verna suggested.Verna said:Please use an electric hair dryer or something that plugs into an electrical outlet to verify there is electrical power at the Alde electric plug. If no electrical power, check for a blown circuit breaker in the converter below the closet door.
- Hash T@B Fun
