@Fiddlerjoebob congratulations and welcome to the Tab family! If it has a rear hatch with kitchen it is a CS. If the CS has a shower and toilet(wet bath) it is a CS-S. If it has kitchen and wet bath inside it is the S model. If it has no kitchen or bath it is the U model. If it has a raised frame and yakima rack on the back it is the Outback model, now called Boondock. There is the Sofitel, high end S model, and the Tabitha, S model with unique interior but is no longer made. When you need help on the forum it is helpful to have the model and year of your Tab included. Different model years have different features. Pictures are always helpful, too. Hope this helps!
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
Ok, thanks...I have the U model, and I found the VIN. And, its a 2015, which I knew. So do I refer to it as a 2015 'T@B U model" ? Is that sufficient nomenclature? What about the numbers like 400 and such I see on posts? Do I have a number like that?
2015 T@B 320Q 2009 VW Touareg Two Fiddles One Bicycle One sewing machine
@Fiddlerjoebob, you have a 2015 T@B 320, U model. If you had a bathroom, it would be an SU model, but you haven’t mentioned the wet bath (S means shower).
I’m not sure the U model came with a bathroom.......
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
https://tab-rv.vanillaforums.com/discussion/624/vin-location
2009 VW Touareg
Two Fiddles
One Bicycle
One sewing machine
So so it’s the 320. Thanks. Can’t wait to get on with it this summer.
Fjb
2009 VW Touareg
Two Fiddles
One Bicycle
One sewing machine
Welcome !
You might find it helpful to download a copy of the Little Guy Marketed 2015 T@B Sales literature for your camper files.
http://library.rvusa.com/brochure/TAB_Brochure_2015.pdf
http://www.tabownersclub.com/wp-content/uploads/2015-Tab-T@B-Camper-Catalog.pdf
Adventures: 51 Nights: 322 Towing Miles 41,200+
