2018 East Meets West Lincoln Rock Swap or Sell
Homebodyatheart
Member Posts: 2,518
Who has gear that they would like to re-home? Let's post now so plans can be made to swap or sell when we get there. You can also put gear out at your site during the home tours.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
Not gear, but Pika1 has made 8 vent covers. He is happy to install them, and is asking $5.00 to cover the cost of materials. To reserve yours he can be reached here on the NuCamp Tab Forum by message, Pika1.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1
Alice Quade from the FB group has a 320 cover to sell. She upgraded to a 400 this spring.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
Also check the post in the T@da, T@b, T@g Camper Owners FB group, under Events. It’s a closed group, but easy to join.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0 -
Eric aka: Lone Wolf1 -
This is the ac vent cover we use on Pika. Great in early spring, fall or cold nights to cut the draft that enters. Keeps the inside warmer and the thermostat is more accurate without the draft. It is left off the rest of the time. The four washers provide grip for two furnace air vent flow directors that help keep excess hot air from re-entering the ac when operating.
We might be interested in a cover. But any chance not having the side with writing on it?2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
aka BirdieJane towed by Quinn0 -
@BirdieJane,@LisaH the covers are made from plain, white plastic material. The washers are white also.0
Sounds great!!!2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
@Pika1, You might want to bring a couple extras for those on the fence that have that need to "touch, see, & feel" syndrome like I have !!!!
Eric aka: Lone Wolf0 -
I’ve got a new switch, very simple to install, to turn your TV screen all the way off, so no phantom power drain. They were sold in packs of two, so it needs a home. $3 covers it and it’s yours!
@Homebodyatheart I will buy the tv switch off if it’s still available. Thanks2018 T@b 320S Boondock, towed by 2012 Toyota Highlander Hybrid0
I also have an extra switch . . . will try to remember to bring it along.Homebodyatheart said:I’ve got a new switch, very simple to install, to turn your TV screen all the way off, so no phantom power drain. They were sold in packs of two, so it needs a home. $3 covers it and it’s yours!
@LisaH I’ll put your name on it! I’m glad it will be used.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
Just checked and three of the ac vent covers are left and looking for a T&B home.0
We would like the tv switch.2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
aka BirdieJane towed by Quinn1 -
Don't forget to check the main post above for this gathering. There's new information!
Bump! Eight days and counting!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1
